Client-side code should not use synchronous AJAX methods (e.g., g_form.getReference, getXMLWait)
app
Mega Expert
created 2mo ago in IT Service Management
Need a solution that for client side code,  synchronous AJAX methods should not be used then how we can use some other thing like script include for the requirement.
Script: function onChange(control, oldValue, newValue, isLoading, isTemplate) {
var caller = g_form.getReference('caller_id');
if (caller.vip == 'true')
g_form.setValue('urgency','1');
g_form.setValue('impact','2');
else
Please suggest me the solution that how this can be improved by not using g_form.getReference().
I have also tried this by using UI policy but still not getting any appropriate result.
Shweta KHAJAPUR
Try to add some logs,
var chkUserRole = Class.create();
chkUserRole.prototype = Object.extendsObject(AbstractAjaxProcessor, {
 chkCallerUserRole: function() {
 var caller = this.getParameter('sysparm_caller');
gs.addInfoMessage('caller_sys_id...'+caller);
var vip = gs.getUser().getUserByID(caller).getRecord().getValue('vip');
gs.addInfoMessage('vip...'+vip);
 return vip;
Client script as below,
 //return;
 var ga = new GlideAjax('chkUserRole');
ga.addParam('sysparm_name','chkCallerUserRole');
ga.addParam('sysparm_caller',g_form.getValue('caller_id'));
ga.getXML(HelloWorldParse);
function HelloWorldParse(response) {
g_form.addInfoMessage('answer...'+answer);
 if(answer=='1')
26 REPLIES 26
Hi
Try with something like this :-
var gr = new GlideRecord("sys_user_has_role");
gr.addQuery("user",caller);
gr.query()
if(gr.next())
return gr.role.getDisplayValue();
Hi
var gr = new GlideRecord("sys_user");
gr.addQuery("sys_id",caller);
if(gr.next())
return gr.vip;
Hi omkar,
my script include:
if(gr.next())
return gr.vip;
please take a look.
Hi
Yes its correct. Just tell me one thing. Is the check box of Client Callable ticked while createing a script include? If not you need to create a new script include. Tick it and then try once again.
Yes it is ticked.
