Client-side code should not use synchronous AJAX methods (e.g., g_form.getReference, getXMLWait)
app
Mega Expert
created 2mo ago in IT Service Management
Need a solution that for client side code,  synchronous AJAX methods should not be used then how we can use some other thing like script include for the requirement.
Script: function onChange(control, oldValue, newValue, isLoading, isTemplate) {
var caller = g_form.getReference('caller_id');
if (caller.vip == 'true')
g_form.setValue('urgency','1');
g_form.setValue('impact','2');
else
Please suggest me the solution that how this can be improved by not using g_form.getReference().
I have also tried this by using UI policy but still not getting any appropriate result.
Shweta KHAJAPUR
Try to add some logs,
var chkUserRole = Class.create();
chkUserRole.prototype = Object.extendsObject(AbstractAjaxProcessor, {
 chkCallerUserRole: function() {
 var caller = this.getParameter('sysparm_caller');
gs.addInfoMessage('caller_sys_id...'+caller);
var vip = gs.getUser().getUserByID(caller).getRecord().getValue('vip');
gs.addInfoMessage('vip...'+vip);
 return vip;
Client script as below,
 //return;
 var ga = new GlideAjax('chkUserRole');
ga.addParam('sysparm_name','chkCallerUserRole');
ga.addParam('sysparm_caller',g_form.getValue('caller_id'));
ga.getXML(HelloWorldParse);
function HelloWorldParse(response) {
g_form.addInfoMessage('answer...'+answer);
 if(answer=='1')
26 REPLIES 26
Hi Omkar,
Created a new script include also. but nothing.
You missed Bracess '{}' after if statement.
Shweta KHAJAPUR
Modify your script include as below and client collable should be checked,
 return gs.getUser().getUserByID(caller).getRecord().getValue('vip');
Hello shweta,
Sorry but nothing happened.
thanks
Modify client script if part,
if(answer=='1')
