closing of problem record only when all the problem tasks are closed
msc
Hi everyone,
In problem record , problem record will  be closed only  when all the ptasks are closed complete. before the record is closed  then a message should be display please close the ptask .
if we cancel the problem record then all the problem task will  be changed to closed complete auttomatically.
9 REPLIES 9
Aman Singh_
Create a before Update BR on Problem table with condition as
Problem Status changes to closed
and use the following in script
var gr = new GlideRecord('problem_task');
      gr.addQuery('active','true');
      gr.addQuery('problem',current.sys_id);
  if (gr.next()) {
    gs.addInfoMessage(gs.getMessage("A task is open. Please complete the task before closing the problem ticket."));
    current.setAbortAction(true);
Mark ✅ Correct/helpful, if applicable, Thanks!!
Aman
msc
if we cancel the problem record then all the problem tasks will  be changed to closed complete auttomatically.
If you have the Cancel UI Action follow what Ankur suggested.
Your initial query is answered, close the thread by marking appropriate answer as correct.
Just a suggestion, try to build it by yourself if they are your assignments during your training period.
Aman
Ankur Bawiskar
@msc
for this point
I assume you must be having Cancel UI Action on Problem table
Server Side Script in UI Action:
(function(){
	try{
		// your code
		var gr = new GlideRecord("problem_task");
		gr.addQuery("problem", current.getUniqueValue());
		while(gr.next()) {
			gr.state = 157; // closed
			gr.update();
	catch(ex){
		gs.info(ex);
