CMDB groups and changes
Eric M
Giga Expert
In the Istanbul and jakatra release came the concept of CMDB groups. anyone using them with change ? and how are you using them?
Best,
Eric
johnfw
Kilo Expert
Hi Eric, wish I could help, but have the same question.
In the CI field in CHG, I want users to be able to select a group, and then all CIs within that group to populate the 'affected CIs' related list.
We tried overriding the reference qualifier with "sys_class_name=cmdb_ci_server^ORsys_class_name=cmdb_group" but this didn't work.
If you have had any luck, please share
John
34 REPLIES 34
Eric M
Giga Expert
this is what i got out of the knowledge 17 slides .. but i don't see the option to use them everywhere
CMDB Groups
-Challenges
-No out-of-box tool to group a list of CIs
-Customers develop their own ad-hoc scripts
Type of Groups
-Manual   group
-Query Builder saved query Encoded Query
-Encoded Query
Benefits
—Allow customizing a group once and use everywhere ---???
—Provide central place to view and add CI to a group
—Provide aggregated view on CI's operational status and actions within a group
Yes, I agree.   While on the surface the CMDB Group seems to have addressed some of the concerns, it does not provide the actual use cases that most people would look to use.
phsdm
Has anyone made any progress on this, or heard from ServiceNow about best practices around cmdb_group and cmdb_ci_group?   Use cases I am interested in:
  1. On a form, the user selects a Category choice.   When they navigate to the Configuration Item field, it is filtered to show only members of a group corresponding to the Category.   Corollary is to filter the Affected Items list based on the Category.
  2. On a form, the user uses a CI Group field to select a CI Group by name.   The Configuration Item field is filtered using that group.   Corollary:   The same applies to Affected Items.
  3. ON a form, the user uses a CI Groups List of CI Group References to select multiple CI Groups.   The Configuration Item field is filtered using that group.   Corollary:   The same applies to the Affected Items related list.
With all of these, I am concerned about how this will scale and perform.   The CMDBGroupAPI script include runs the queries and returns an array of Sys IDs.   This is fine for a group holding a few hundred CIs.   But how will it perform with a group holding thousands?   If a group holds hundreds of thousands will memory errors and pauses of seconds become an issue?
Is there an Auto-Completer that works with one or multiple CMDB Groups?
Is there a way to convert a query built with the CMDB Query builder into something can be submitted as part of an encoded query?
If an auto-completer could refactor the clauses of one or more CMDB Groups into a single [encoded] GlideRecord query, then interactive selection of a CI from a large CMDB Group (hundreds of thousands of CIs) would scale.
I haven't heard a things
JB23
Mega Contributor
I am also interested in # 2 from your list. It would seem an intuitive use for CMDB Groups but after an hour of futzing with it last night, no dice.
