07-23-2018 05:27 AM
I Have a requirement to compare the two string fields data and the difference need to be populated in the 3rd field.
1st field name: user input
2nd field name: existing data
3rd field name: missing data:
1 st field data : 1,2,3,4,5,6
2nd field data : 2,5,6
i need to compare the data between 1st field and 2nd field and difference should be populate in 3rd field.
3rd field data: 1,3,4
Thanks in advance,
kumar
07-23-2018 07:39 AM
I created an item in my dev instance and re-did the code. Try this you will just need to update the variable names as I created them as a, b, and c.
var a = g_form.getValue('a').toString().split(',');
var b = g_form.getValue('b').toString();
getDifference(a, b);
function getDifference(a, b)
// var j = 0;
var result = [];
for (var i = 0; i < a.length; i++){
if (b.toString().indexOf(a[i]) < 0){
result.push(a[i]);
g_form.setValue('c', result);
07-24-2018 05:24 AM
thank you bricast. i will check the issue
07-24-2018 07:05 AM
Hi bricast,
just small help.
the proposed solution is having issue with case sensitive.
input: ADCADM03,
database: adcadm03,
even though it is present in the database with lower case letters . it is giving the input as missing servers.
output missing servers: ADCADM03,
can you please help me on it.
var a = g_form.getValue('u_impacted_ci').toString().split(',');
var b = g_form.getValue('u_cmdb_ci_data').toString();
// var j = 0;
var result = [];
result.push(a[i]);
g_form.setValue('u_missing_servers', result);
thanks,
dileep peddi
07-24-2018 07:30 AM
for case sensitive you can trying making the changes to the following code.
var a = g_form.getValue('u_impacted_ci').toString().toLowerCase().split(',');
var b = g_form.getValue('u_cmdb_ci_data').toString().toLowerCase();
07-24-2018 07:24 AM
hi bricast,
thank you. issue has been fixed.
07-23-2018 05:39 AM
Hi Kumar,
So basically it is a difference you need to get
Here is the sample script
var field1Data = '1,2,3,4,5,6';
var strArray = field1Data.split(",");
var field2Data = '2,5,6';
var str1Array = field2Data.split(",");
var arrayUtil = new ArrayUtil();
var diffArray = arrayUtil.diff(strArray, str1Array);
Mark Correct if this solves your issue and also hit Like and Helpful if you find my response worthy based on the impact.
