Comparison between two string fields data
kumar37
Giga Contributor
I Have a requirement to compare the two string fields data and the difference need to be populated in the 3rd field.
1st field name:  user input
2nd field name: existing data
3rd field name: missing data:
1 st field data :  1,2,3,4,5,6
2nd field data : 2,5,6
 i need to compare the data between 1st field and 2nd field and difference should be populate in 3rd field.
3rd field data: 1,3,4
Thanks in advance,
kumar
I created an item in my dev instance and re-did the code.  Try this you will just need to update the variable names as I created them as a, b, and c.
	var a = g_form.getValue('a').toString().split(',');
	var b = g_form.getValue('b').toString();
	getDifference(a, b);
function getDifference(a, b)
//	var j = 0;
	var result = [];
	for (var i = 0; i < a.length; i++){
		if (b.toString().indexOf(a[i]) < 0){
			result.push(a[i]);
	g_form.setValue('c', result);
30 REPLIES 30
Abhinay Erra
does these fields always contain comma separated values?
Yes Abhinay
Chuck Tomasi
You might find the script include in this article helpful. It can cut down on the amount of code you need to write and centralizes that functionality for easier testing.
Abhinay Erra
Here you go. Put this in the client script
var arr1=g_form.getValue("field name of 1st field").split(',');
var arr2=g_form.getValue("field name of 2nd field").split(',');
g_form.setValue("field name of 3rd field",arr_diff(arr1,arr2));
function arr_diff (a1, a2) {
    var a = [], diff = [];
    for (var i = 0; i < a1.length; i++) {
        a[a1[i]] = true;
    for (var i = 0; i < a2.length; i++) {
        if (a[a2[i]]) {
            delete a[a2[i]];
            a[a2[i]] = true;
    for (var k in a) {
        diff.push(k);
    return diff.join();
Hi Abinay,
Thanks for your reply.
irrespective of the input it is giving the output. not related data also coming as output .can you please help on this.
