Comparison between two string fields data
kumar37
Giga Contributor
I Have a requirement to compare the two string fields data and the difference need to be populated in the 3rd field.
1st field name:  user input
2nd field name: existing data
3rd field name: missing data:
1 st field data :  1,2,3,4,5,6
2nd field data : 2,5,6
 i need to compare the data between 1st field and 2nd field and difference should be populate in 3rd field.
3rd field data: 1,3,4
Thanks in advance,
kumar
I created an item in my dev instance and re-did the code.  Try this you will just need to update the variable names as I created them as a, b, and c.
	var a = g_form.getValue('a').toString().split(',');
	var b = g_form.getValue('b').toString();
	getDifference(a, b);
function getDifference(a, b)
//	var j = 0;
	var result = [];
	for (var i = 0; i < a.length; i++){
		if (b.toString().indexOf(a[i]) < 0){
			result.push(a[i]);
	g_form.setValue('c', result);
30 REPLIES 30
var arr1=g_form.getValue("u_impacted_ci").split(',');
var arr2=g_form.getValue("u_cmdb_ci_data").split(',');
g_form.setValue("u_missing_servers",arr_diff(arr1,arr2));
function arr_diff (a1, a2) {
var a = [], diff = [];
for (var i = 0; i < a1.length; i++) {
a[a1[i]] = true;
for (var i = 0; i < a2.length; i++) {
if (a[a2[i]]) {
delete a[a2[i]];
a[a2[i]] = true;
for (var k in a) {
diff.push(k);
return diff.join();
