connecting to oracle
05-18-2016 03:47 PM
I'm trying to connect to oracle database, query a table and preparing a dashboard using the data.
I navigated into ' system import sets --> administration--> data sources' and provided the details of my oracle instance.
the issue here is
1. i'm not able to connect to the database
2. I dont know what to do next to see the results
3. how do i build a chart/dashboard using the data.
I'm sorry i'm completely new and a first time user to service now. please guide me through
Appreciate your help in advance.
05-19-2016 10:04 PM
Hi Kadambari,
It seems that you are not using a MID-Server - I missed your earlier screenshot of the data source where "Use MID Server" is empty.
<earlier>
I can advise there is no connectivity to the db from the Internet in general.
$ telnet lnxdb-dev-vm-218.cisco.com 1521
Trying 173.38.3.24...
telnet: connect to address 173.38.3.24: Operation timed out
telnet: Unable to connect to remote host
</earlier>
1) Your ServiceNow instance could connect to the db - if the instance source IPs are allowed through the Enterprise firewall.
or
2) You could install a MID-Server in the Enterprise and specify the MID Server in the data source.
You need to reach out internally to arrange one of the above choices.
Best Regards
Tony
06-01-2017 10:48 AM
tony.barratt is this doable without a MID? i would like to set up a oracle connection via jdbc for location info to be imported. I should be able to do this using a data source correct?
11-16-2020 06:33 PM
Hi Tony,
I am in process of connecting ServiceNow instance to Oracle database. My requirement is to get data from Oracle, transform and populate in ServiceNow.
I tried loading 20 record and got the same Network connectivity issue as mentioned in the earlier query.
I am using MID server. Wanted to understand if we need to do any changes in MID server configuration or any other setting to establish the connection.
Many thanks
Nitin
05-08-2023 04:57 AM
Hello friends Could you please help me. I am also having the same query. It will be really helpful.
