Convert reference field LOCATION to display name instead of Sys ID
IB98
HI All,
(Catalog Item) I am trying to get the variable 'location' to auto populate with the requester information. Initially, the location populates with the signed in requester because I have a default javascript in place that does that. If I change the user, the OnChange script is supposed to set the value for that user, instead it displays the sys id. I did check the display on the location table and it's set to true on name. I am out of ideas. Please help!
I will include the variable default code and the Catalog client script. Also, the location variable is set to a single line text variable.
*I have tried both options that are commented out. The above script works for phone and email variables.
*Location (Single line text variable) to populate 'Requester' (variable set variable) Location
IB98
Thank you all for your help! I used this code and it helped.
Script Include
var getLocation = Class.create();
getLocation.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    get_location: function() {
        gr.addQuery('sys_id', this.getParameter('sysparm_userID'));
        if (gr.next()) {
            return gr.location.getDisplayValue();
    type: 'getLocation'
OnChange Catalog Client script
    var ga = new GlideAjax('getLocation');
    ga.addParam('sysparm_name', 'get_location');
    ga.addParam('sysparm_userID', g_form.getValue('requester')); //the variable name from the variable set
    ga.getXMLAnswer(function(answer){
       //if(answer != ''){
       g_form.setValue('location', answer);
Anurag Tripathi
Mega Patron
Mega Patron
This dot walk feature on will not work on the getReference function. you will have yo use GlideAjax  and then return the fields needed from server side
-Anurag
-Anurag
naman1
Please try to use GlideAjax Call in order to get the display value of location field. You can return multiple values from Script Include using JSON object. Please try the below code in Script Include.
getUserData: function() {
var gruser = new GlideRecord('sys_user');
var user = this.getParameter('sysparm_user');
if (gruser.get(user)) {
var json = new global.JSON();
var results = {};
results.first_name = gruser.getValue('email');
results.last_name = gruser.getValue('phone');
results.location= gruser.getDisplayValue('location');
return json.encode(results);
IB98
Script Include
        if (gr.next()) {
    type: 'getLocation'
       //if(answer != ''){
