07-18-2019 07:21 AM
In London and Madrid I can create multi-row variable sets and get them to display in the formatter for the submitted record using a record producer. I want to be able to copy the variable set to another task. I can do this using the question_answer table, but the variables don't get formatted like a multi-row variable set. I tried also creating records in the sc_multi_row_question_answer table and it doesn't seem to make a different. The Row index field can't be the only thing, because I tried creating a record using a record producer that rendered the multi-row variable set correctly, duplicating the records and deleting the old ones and it still would render my new variables as a table.
Any missing pieces in this equation? I couldn't find any other tables that might be involved or fields on the question_answer table or sc_multi_row_question_answer table.
Thanks!
Multiple Versions
Service Catalog
- 9,078 Views
08-20-2020 09:37 AM
I might have found the missing piece!
You need to create a record in the table sc_item_produced_record. The formatting seems to be correct as well.
In my code I added this snipppet. This piece is targeted at a single catalog item, and towards the change_request table. It should be easy enough to modify this to accomodate other producers and tables.
function createProducedRecord(change_id) {
var producer = new GlideRecord("sc_cat_item");
producer.addQuery("name", "<name of record producer / cat_item>");
producer.query();
if (producer.next()) {
var produced_record = new GlideRecord("sc_item_produced_record");
produced_record.initialize();
produced_record.record_table = "change_request";
produced_record.task = change_id;
produced_record.record_key = change_id;
produced_record.producer = producer.getUniqueValue();
produced_record.insert();
01-29-2021 03:54 AM
This works !
08-14-2026 06:12 AM
Will you be able to provide me with the full code of how it's done?
