Create a Floder to MID Server by Flow Designer
chunn
Hi,Can you tell me?
I Want to  create a folder on the MID server with the incident number as the folder name when an incident is raised in ServiceNow by Flow Designer.
by the way How does MID Server appear in Flow Designer?
Best!
Hi, sure
4)
Please make sure you installed either Integration Hub Professional or Integration Hub Enterprise packs as Starter does not have these steps indeed.
6)
You create an Action with one input variable ("Folder name"), add this action to the flow and set a data pill for the action' input that points to the Inc' Number from the flow' trigger (Record Created in Incident table).
Hope it helps
Hi,Thank you very much to help me. I try it !
Best!
