Create Catalog task
Hello All,
I have an requirement to create an catalog task and associate to Existing RITM , So can I please have some sample script to develop this
So in the payload what details do they need to send etc
@jaheerhattiwale
2 ACCEPTED SOLUTIONS
@Community Alums
update as this
Ensure you link that sc_task with that RITM and REQ
Also I assume 3rd party will send data like this
"request_item":"RITM001"
(function process( /*RESTAPIRequest*/ request, /*RESTAPIResponse*/ response) {
	var ritmNumber;
	var payload = request.body.dataString;
	if (JSUtil.isEmpty(payload))
		return new sn_ws_err.BadRequestError("No data provided");
	var parsedData = JSON.parse(payload);
	ritmNumber = parsedData.request_item;
	var ritm = new GlideRecord('sc_req_item');
	ritm.addQuery('number','ritmNumber');
	ritm.query();
	if(ritm.next()){
		var gr = new GlideRecord('sc_task');
		gr.request_item = ritm.getUniqueValue();
		gr.request = ritm.request;
		gr.initialize();
		var taskId = gr.insert();
		// Return the created SC Task details in the response
		var responseBody = {
			number: gr.number.getDisplayValue(),
		response.setStatus(201); // 201 - Created
		response.setBody(responseBody);
})(request, response);
@Community Alums Use updated code below to add the assignment group as well
    var payload = request.body.data;
    if (!payload) {
        return new sn_ws_err.BadRequestError("Request body is empty");
    if (!payload.ritmNumber) {
        return new sn_ws_err.BadRequestError("Request body does not contain the RITM number");
    var ritmNumber = payload.ritmNumber;
    ritm.addQuery('number', ritmNumber);
    ritm.query();
    if (ritm.next()) {
        gr.initialize();
        gr.parent = ritm.sys_id.toString();
gr.request_item = ritm.sys_id.toString();
gr.assignment_group = payload.assignment_group;
        gr.short_description = "New catalog task";
        gr.insert();
            number: gr.number
Payload should be:
{"ritmNumber": "RITM0010049", "assignment_group":"<GROUP SYS ID HERE>"}
Please mark as correct answer if this solves your issue.
Please mark the answer as correct or helpful based on impact
ServiceNow Community Rising Star, Class of 2023
20 REPLIES 20
Hello @jaheerhattiwale ,
Am getting following error while Testing the API
    "error": {
        "message": "Requested URI does not represent any resource",
        "detail": null
    "status": "failure"
can you please take a look
@Community Alums You are trying it from postman? The scripted rest resource url (end point) you use used is not correct i think. please check.
@jaheerhattiwale , same works in Rest API but not here in postman
@Community Alums Send screenshot of scripted rest resource record and postman?
@jaheerhattiwale , here it is
