Create Multiple records using JSON Payload
Vamshi_ch123
Hi @PavanK960672992
Trying to create multiple records from JSON using the below script but the records are not inserted.
Script:
var reqbody = request.body.data;
var  parsedData = reqbody.alerts;
gs.info("event : REQ " + reqbody);
for(var i=0; i<parsedData.alerts.length; i++){
	var gr = new GlideRecord("em_event");
	gr.initialize();
	gr.setValue("description",parsedData.alerts[i].annotations.summary);
	gr.setValue("node",parsedData.alerts[i].labels.Customer);
	gr.insert();
	gs.info("testevent : val " + parsedData.alerts[i].valueString);
-Thanks
Rahul Kumar17
It looks like there is an issue with the loop and the way you are accessing the parsedData variable. Based on the code you provided, it seems you are trying to insert multiple records into the em_event table based on the JSON data contained in the reqbody.alerts array.
Let's make some modifications to the script to fix the issues:
var reqbody = JSON.parse(request.body.data); // Parse the JSON data to a JavaScript object
gs.info("event : REQ " + JSON.stringify(reqbody));
for (var i = 0; i < parsedData.length; i++) {
    gr.initialize();
    gr.setValue("description", parsedData[i].annotations.summary);
    gr.setValue("node", parsedData[i].labels.Customer);
    gr.insert();
    gs.info("testevent : val " + parsedData[i].valueString);
Rahul Kumar
If my response helped please mark it correct and close the thread.
Rahul Kumar
