Create problem ticket from Incident record for closed incident not showing " Create Problem"
B Ashok
Hi Team,
" Create Problem" from context menu on incident  record page is showing only when incident is in  open, inprogress, on-hold and resolved. but not showing when incident is in closed state.
Please see below screenshots.
SumanthDosapati
Hi @Ashok B
That is the Expected functionality. You can have the Create Problem option in Incidents only if it is not closed.
The reason is, If the issue in the incident is already fixed then incident will be closed so there will be no use of creating a problem if it is already fixed.
Mark it as correct or helpful if it does.
Sumanth
SumanthDosapati
Hi @Ashok B
Sumanth
