Create problem when more than 5 incidents with same CI
ramkrish
Hi
I have coded below in after insert BR of incident. But it is not working, can you help here?
var inc=new GlideRecord('incident');
inc.addQuery('cmdb.ci', current.cmdb_ci);
  gs.log('count is:' +current.cmdb_ci);
inc.query();
if (inc.next())
  var count=inc.getRowCount();
  gs.log('count is:' +count);
if (count >5)
  var pbmtbl=new GlideRecord('problem')
  pbmtbl.initialize();
  pbmtbl.short_description=current.short_description;
  pbmtbl.state='Open';
  pbmtbl.insert();
Michael Fry1
What you have is good start, just a few minor changes:
                      inc.addQuery('cmdb_ci', current.cmdb_ci);
                      inc.addQuery('incident');
                      gs.log('cmdb: ' + current.cmdb_ci.name);
                      inc.query();
                      if (inc.next()){
                                              var numb = inc.getRowCount();
                                              gs.log('count is: ' + numb);
                                              if (numb >5){
        var pbmtbl=new GlideRecord('problem');
        pbmtbl.insert();
Shishir Srivast
Please try this
  // Add your code here
  var ci = current.getValue('cmdb_ci');
  inc.addQuery('cmdb_ci', ci);
  inc.addActiveQuery();
  inc.query();
  if (inc.next())
  if (inc.getRowCount() >= 5)
  pbmtbl.insert();
})(current, previous);
preddy
Hi Ramakrishna,
Create Business rule on After update and you can pass condition
Condition : configuration item changes and problem isEmpty
Code:
var inc = new GlideRecord("incident");
      inc.addQuery("cmdb_ci",current.cmdb_ci);
      inc.query();
      if(inc.getRowCount() > 5){
              var prb = new GlideRecord('problem');
              prb.initialize();
              prb.short_description="Creating "+current.cmdb_ci.getDisplayValue();
              prb.insert();
Pavan Dodla
I hope this helps. Please mark correct/helpful based on impact
THIYAGESHWARAN
  1. if more than 5 incidents got created and active but not resolved state got created on the same configuration item then after creating 5th incident the remaining 4 incidents should be made a child of 5th incident
 any one pls support
SanaPR
Giga Guru
Hi @ramkrish ,
Have you figured out the solution? Could you please share the same , we have a similar requirement and I dont see any workable solutions yet,
Thank you!
