CSRF Token Mismatch error?
poornachander
Mega Expert
Any idea about the following error message keep occuring
Preventing auto-resubmit for user: xxxxxxxxxx after reaching max count for CSRF token mis-matches!: no thrown error
making the property glide.security.csrf.strict.validation.mode to False worked.
12 REPLIES 12
If it's not defined then by default (in Fuji) we are giving the error after 50 re-submits.
Is this happening on log in phase or on other pages as well ?
Sergiu
login page...& others too
        a popup appears repeatedly saying your session expired, on clicking cancel several times...it allows to home page and other pages throwing up the error on top of the page: Preventing auto-resubmit for user: xxxxxxxxxx after reaching max count for CSRF token mis-matches!: no thrown error
and dialog appears again and again...
Unfortunately I don't know what else you could check. You should open an incident with ServiceNow as we need to have a look at the instance.
Sergiu
Hi @sergiu.panaite ,
what is the value of the property "csrf.token.fail.count"? I cannot find it in our system. The only system properties related to csrf are:
glide.security.csrf_previous.allow
glide.security.csrf_previous.time_limit
glide.security.use_csrf_token
Best,
Friedrich
poornachander
Mega Expert
Thanks very much Sergiu Panaite
