current.setAbortAction(true) doesn't work if nothing is changed to the incident record
natecousins
I have a "before" Business Rule to prevent an update to an incident record if the 'Assigned to' user is not a member of the 'Assignment Group'. The BR only runs on 'Update', but only seems to work if you modify the record like change the value of a field. If you do not make any changes, the BR will not work.
I have set the Order field to 1 and to the low number like 10,000. Still doesn't work. I have added current.setWorkflow(false), and it still doesn't work.
The conditions are: assigned_to is not empty AND assignment_group is not empty
CODE:
// Add your code here
var assigned_to = current.assigned_to;
var assignment_group_display = current.assignment_group.getDisplayValue().trim();
var assigned_to_display = current.assigned_to.getDisplayValue().trim();
var userObj = '';
userObj = gs.getUser().getUserByID(assigned_to);
if (!userObj.isMemberOf(assignment_group_display)) {
var msg = gs.getMessage('ERROR: ' + assigned_to_display + ' is not a member of ' + assignment_group_display + '. Please ensure the "assigned to" user is a member of the "assignment group".');
current.setAbortAction(true);
current.setWorkflow(false);
gs.addErrorMessage(msg);
})(current, previous);
Any thoughts why?
21 REPLIES 21
Hi nate,
Please validate if the code works and changes made by user are not saved.
Let me know how the provided script works?
Best Regards,
Rahul
Laurie Marlowe1
You could create a WRITE ACL to check if the user is a member of the assignment group.  If not they will not have write priviledge.
Laurie
Please mark Correct or Helpful, as applicable1
