Customization of Project Status Portal in PPM
raj1989
Hello All,
There are default columns in the project status portal like Number, Short Description, Manager, Portfolio, Percent Complete, Planned Start Date, Planned End Date, Overall Status. If I want to add the new columns or the customized columns in the project status portal. What is the process? How can I do that?
20 REPLIES 20
Hi Raja,
As Abhishek replied for your earlier post, Please add "state" in JSON format.
I have tested in my dev instance, it is working fine.
save it after adding the state and now again reloadthe project status portal.
Hello Harish,
Thanks for your response.
'primary_program' this field is on the project form. But, when I have added the 'program' field it has been added to the column. So, now to add the custom field in column which has been added on the project form.What should I do?
if you are adding your custon filed in JSON format, in that UI page.
what is it displaying ?.
is that custom fields has any values ?
can you post the screenshot.
it displaying nothing.
Hi Hahrish,
I hate to ask this question twice, but would you be able to help?   I am having an issue with my custom columns not showing the correct value. In the screen shot you can see my project manager fields showing the sys_id instead of the user referenced. Same with project status and the the date fields which is a custom Actual Start Date. Any thoughts?
