Data Lookup Definition
snehalkhare
Hi
I want to set the assignment group based on category and subcategory for problem using data definition
Steps done by me
1.create custom table --Name : Problem Assignment Lookup   ; extends table : [dl_matcher]
2.created the required fields i.e category,subcategory and assignment group
3.Data Lookup definition > New>Data Lookup Rule
Name:Problem Assignment Lookup
source : Problem
matcher :   Problem Assignment Lookup(custom table)
4. have set the matcher and setter fields
Issue is that when I am opening the data lookup table to set the values , then the Choice list Values for these are not available .So I'm unable to enter the values.
How to solve this issue ?
Snehal
You do not need to create any fields. If you are referring to no drop downs in this field, I misunderstood:
You'll just need to edit the dictionary on each field like this:
However, if you're referring to unable to set drop downs on the Setter field definition, then my original post is the answer. You'll just need to modify the Setter form to add those fields to the form.
Hi
Which fields do we need to create exactly ?-I am having Source table and Matcher table on right side of the slush bucket .
Need to add means do we need to create new fields or are available OOB ?
Snehal
Thanks a lot
It was very helpful
You are welcome!
