Difference between Child Incidents and Incident Tasks
‎02-01-2022 04:27 AM
Currently in our instance, agents can create both Incident Tasks as well as Child Incidents on an Incident. We need to get a better understanding into the differences between the two, the use cases both of these serve, is it best to keep both enabled?
‎03-12-2024 03:52 AM
Thank you @Sourabh26, That's a clean one.
I appreciate it!!
‎02-02-2022 04:48 AM
Hi. If some answers have helped you, mark them Helpful and/or Correct in order to close the case. Thanks!
‎02-02-2022 05:04 AM
Hi Manpreet ,
Please mark answer correct and helpful so that this thread will mark as correct and remove from the question list.
thanks
Sanjay Bagri
‎03-22-2022 11:16 AM
Hi. If your issue is resolved and my response has helped, plese consider marking Correct and Helpful. Thanks!
Martin Ivanov
2022 Community Rising Star
