Display Business Rule Not Working In Domain Separated Instance
FA94
We have recently upgraded our Domain Separated instnace to San Diego and after the upgrade the Display business rules don't seem to be working at all. Any idea what might be causing this?
Thanks!
Veena Vanaparth
It is a known error in the San Diego release which has been fixed in the San Diego Patch 2 release. There is a workaround that can be used before you upgrade to this release.
The workaround can be applied by setting the system property "glide.sys.domain.use_domain_business_rule_info_optimization" = false.
If the property does not already exist in the sys_properties table, you can create a new record as outlined below:
Type: true | false
Value: false
Veena Vanaparth
Type: true | false
Value: false
Veena, do you know the PRB related to this issue?  I'm on patch 7 and still need to use the workaround.
Tom
