Duration field value not displaying properly in reporting
jomandy
Kilo Explorer
I have created a new field on the Incident table with a type Duration to calculate the age of open incidents (datediff from opened to today). The calculation works and the field displays correctly on the incident form, however I am not able to report off of this field correctly.
First - if I create a list report I see the values (eg. 2 days 11 hours and 29 minutes) but I can't sort this column. I can sort other duration columns, like Business Duration, that display the data in the same format.
Second - If I create a chart report it automatically tries to group the duration in Report Ranges but doesn't recognize the amount of time. So I get a bar chart with all the incidents in the 'empty' column and all the ranges (same day, 2-5 days, etc) have a count of 0.
I believe this is linked to a formatting issue but I've had no luck finding anything online.
Any help is much appreciated, and please let me know if you need additional details.
The code (and method) I'm using is from here: Catalog Task (up-to-the-minute) Aging Report
gs.dateDiff(current.opened_at.getDisplayValue(),current.closed_at.getDisplayValue(),false);
I ended up working around this by not using a calculated value and instead creating a new business rule similar to the "mark_closed" business rule on the problem and incidents tables to populate the field.
Thanks for pointing me to the right direction.  I got the duration field working in the sc_task table now.  When you created your BR were you able to retroactively run the BR for the closed task prior to creating the BR.
I am only able to get the duration for current tasks that were closed after i created the BR and not before
Nilanjan1
Hello All,
I am into a same fix here, I was able to create a metric which would calculate the duration based on various states I am able to see it in the metric list that the duration is working as expected...with various stages..but in the report I am unable to capture the value in which the task is currently in. Can someone help on this.
(function createMetric(definition,current){
	var mi = new MetricInstance(definition,current);
	var gr = mi.getNewRecord();
	gr.start = current.sys_created_on;
	gr.end = current.sys_updated_on;
	gr.duration = gs.dateDiff(current.sys_created_on,current.sys_updated_on);
	gr.calculation_complete = true;
	gr.insert();
})(definition,current);
