05-12-2021 11:24 PM
We are looking to set up a automated process to add users to a specific group and remove them dynamically once or twice a day. Group membership criteria would be:
Active = true
Locked Out = False
Employee Type = Internal or External
Email Ends with "sec.com"
If people qualify they are put in the list, if they do not qualify they are removed. What would be the best way to achieve this with a script? Would appreciate if I can get a sample script for this.
Thank you.
05-14-2021 11:31 PM
Hi Bruce,
something like this
var rec = new GlideRecord('sys_user');
rec.addActiveQuery();
rec.addQuery('locked_out', false);
rec.addQuery('employee_type','IN','external,internal');
rec.query();
while(rec.next()){
if(rec.email.toString().endsWith('sec.com')){
var gr = new GlideRecord('sys_user_grmember');
gr.addQuery('user', rec.sys_id);
gr.addQuery('group.name', 'Group ABC');
if(!gr.next()){
gr.initialize();
gr.user = rec.sys_id;
gr.group.setDisplayValue('Group ABC');
gr.insert();
05-13-2021 07:50 AM
For removing user from group you can do this
1) After update business rule on sys_user table
Condition: Active [Changes To] False
Script: // remove this user from group
For adding the users satisfying your condition to the group you can run schedule job daily
05-13-2021 07:52 AM
One more ask please. Using the criteria, can you provide a scheduled job script sample? Thanks
05-14-2021 08:08 AM
Hi Ankur,
Thanks for your help. Would it be possible to get a sample of what the scheduled job scrip looks like with the criteria? Thanks
05-14-2021 11:31 PM
Hi Bruce,
something like this
rec.query();
while(rec.next()){
if(!gr.next()){
gr.initialize();
gr.insert();
05-19-2021 10:20 PM
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
