Edit button list collector reference
A_112
I have a related list present on a custom table and I have configured an 'Edit' button on this related list. My query is regarding the list collector that a user will see when clicked on this 'Edit' button. Currently the 'Edit' option on related list opens list collector with a list of values from say in left bucket from say Table A. This Table A has a field which references Table B. Hence when a user clicks on Edit button, I want that the user sees the values from Table B.
Please see an example with screen grabs in the attachment.
Currently I am trying to achieve this using relationships (sys_relationship) table but no luck with this.
Thanks in advance.
Chuck Tomasi
Have you taken a look at Many-to-many tables? The classic example I use is groups and users. You can have many users in a group and many groups assigned to a user. When you see the list on the user profile, it says "groups" and clicking the edit button brings up a list of groups. When you see the list on the group table, it says Users and brings up a list of users when Edit is clicked.
I got it working using many to many table relation. I just had to change the 'From Table' to get this working. I came across 'Edit' button UI action which is looking up sys_m2m table for any entry related to the current table i.e. the table on which the related list is present. Thanks.
Sorry for the late reply. The notification ended up in the incorrect inbox. Did you get your issue resolved? If not, let me know if I can be of additional help. If so, please mark the correct response above as the correct answer so others with similar questions/issues can find it in the future. Thank you.
