Explanation required reg getUserByID() method
Prasanthi1
Giga Contributor
Internal Explanation required for me.
var newUser = gs.getUser ();
gs.print (newUser.getUserByID ('abel.tuter').getFirstName ());
I didnot understand this, kindly explain line by line.
Hi @Prasanthi
 gs.getUser() -since it gives you a reference to the user object for the current user, it means you are getting control access to the whole user object.
If you use below code
var newUser = gs.getUser();
gs.print (newUser.getFirstName());
since you didn't mention any specific user for whom you need first name, it will give you your firstname i.e., current logged in user first name
but you have choosed the user_name in getUserByID ('abel.tuter'), so within the users list, it will identify which user has this UserID -abel.tuter and gives you that user firstname.
Methods does not serve always one purpose , based your requirement you extend your code to use it more.
Here is another link which might be useful for you
https://sn.jace.pro/docs/glideuser/
Kindly mark the response correct and helpful, once your issue is resolved and close the thread for others benefit in future
BR,
Harika
Hi @Prasanthi
BR,
Harika
Thank you for your answer and explanation. I totally understood. Thanks again
Happy to help 🙂
