Field Label
tushar_ghadage
Hi Everyone,
we have implemented a field on RITM level but when end user changes the language of the instance to Norwegian from setting in the profile section, end user sees the field in English only which she should see in her Norwegian language.
I am not sure how should do this can anyone help??
Thanks!!
@tushar_ghadage
Glad to know.
Please mark my below response as correct so that it helps other members
16 REPLIES 16
also one thing overtime is boolean field
that may be an issue ?
Juhi Poddar
Hi @tushar_ghadage
Follow these steps to meet your requirement:
  • Navigate to the System Dictionary entry for the field you want to translate.
  • In the related lists, click on Labels.
  • Click New to create a translation record for the Norwegian language.
  • Enter the translated label text.
Note: Make sure the Element name remains same as it is in English language.
Hope this helps!
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps future readers to locate the solution easily and supports the community!"
Thank You
Juhi Poddar
