02-20-2022 11:40 PM
HI Team,
I have a record producer. Inside record producer i have created a multi row variable set name calle d as "item_list". Inside multi row variable set i had 6 variables.
As soon as i submit the record producer from portal, A record is creating to that table but fields are showing empty.
So how can i map those MRVS variable content inside native view table fields?
I had created a before Business rule to map MRVS to table fields but not working
the MRVS log is showing error like below
var value = current.variables.items_list; // MRVS variable name here
gs.log('Inside :', value);
var parser = JSON.parse(value);
gs.log(parser);
var addtable = new GlideRecord('x_pl4_move4u_item');
for(var i=0;i<parser.length;i++){
addtable.name = parser[i].name;
addtable.move_request = parser[i].move_request;
addtable.is_fragile = parser[i].is_fragile;
addtable.category = parser[i].category;
addtable.short_description = parser[i].short_description;
addtable.volume = parser[i].volume;
addtable.insert();
})(current, previous);
02-21-2022 03:24 AM
are you using correct variable name within mrvs here?
var parserList = JSON.parse(producer.items_list);
current.name = parserList[0].name;
current.move_request = parserList[0].move_request;
current.is_fragile = parserList[0].is_fragile;
current.category = parserList[0].category;
current.short_description = parserList[0].short_description;
current.volume = parserList[0].volume;
02-21-2022 03:22 AM
02-21-2022 03:24 AM
02-21-2022 03:41 AM
HI ANkur,
If suppose i will add 5 rows then i need to create 5 records. How to achieve this?
02-21-2022 03:52 AM
like this
for(var i=0;i<parserList.length;i++){
addtable.initialize();
addtable.name = parserList[i].name;
addtable.move_request = parserList[i].move_request;
addtable.is_fragile = parserList[i].is_fragile;
addtable.category = parserList[i].category;
addtable.short_description = parserList[i].short_description;
addtable.volume = parserList[i].volume;
addtable.insert();
ankur
02-21-2022 03:55 AM
