Fix script
DeveloperG
ServiceNow fix script to close an SCTASK and ensure the associated RITM is updated accordingly using
Its_Azar
Hi there @DeveloperG
Try this script
(function executeFixScript() {
    var taskGR = new GlideRecord('sc_task');
    taskGR.addQuery('state', '!=', '3');
    taskGR.query();
    while (taskGR.next()) {
        taskGR.state = 3;
        taskGR.work_notes = 'Closed by fix script.';
        taskGR.update();
        if (taskGR.request_item) {
            var ritmGR = taskGR.request_item.getRefRecord();
            var allClosed = true;
            var checkTasks = new GlideRecord('sc_task');
            checkTasks.addQuery('request_item', ritmGR.sys_id);
            checkTasks.query();
            while (checkTasks.next()) {
                if (checkTasks.state != 3) {
                    allClosed = false;
                    break;
            if (allClosed) {
                ritmGR.stage = 'closed_complete';
                ritmGR.work_notes = 'Closed automatically as all tasks are complete.';
                ritmGR.update();
If this helps do accept the solution thanks.
☑️ If this helped, please mark it as Helpful or Accept Solution so others can find the answer too.
Kind Regards,
Azar
Serivenow Rising Star ⭐
Architect@ KPMG.
Its_Azar
Try this script
    taskGR.query();
        taskGR.state = 3;
        taskGR.update();
            checkTasks.query();
                    allClosed = false;
                    break;
            if (allClosed) {
                ritmGR.update();
Kind Regards,
Azar
Architect@ KPMG.
