Flow Designer executions stuck approvals not triggering.
03-05-2026 02:23 AM
03-05-2026 02:24 AM
Try to repair /update the plugin once.
03-05-2026 02:41 AM
Hi @Jayesh 315,
This usually happens when the Flow Engine or worker queue gets stuck in the instance. Because of that, the flow context cannot process the next step, so the flow stays “In Progress," and approvals don’t move forward. The message “Waiting for flow execution data” indicates the execution details are not being processed.
You can check the Flow Context and System Logs for errors and try restarting or retrying the flow. If multiple flows are stuck, it’s likely an instance issue.
If you find my answer useful, please mark it as Helpful and Correct. 😊
Soham Tipnis
ServiceNow Developer || Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
03-05-2026 03:23 AM
I know It's instance issue But what exactly we have to do here??
03-05-2026 03:33 AM
There is nothing we can do about it, unfortunately, because PDI is not supported by the Now Support, so it's better to wait and have patience.
Make sure you copy the flow.
