Flow Designer 'For Each' logic error
Amed M
Mega Contributor
Hi, need assistance understanding the error I'm getting here or why it's occurring.  I'm attempting to make a flow that migrates a set of stories from ServiceNow to Jira via the Jira Spoke application.
I start with 'Look up Records' which finds the 118 records.  But then when using flow logic 'For Each' item in Look up Records, it only runs the first iteration and errors out thereafter.
Attached is the log information above 4 errors
Amed M
Mega Contributor
Hi, Thank you for the quick responses.  I actually figured out why the 'for each' was only running on first iteration.
For the step "Look Up Jira Test User ...", It was was erroring out on first iteration so I had to select "don't fail on error" for this step in the flow.
This allowed the "for each" to continue.
I have a new problem now, however.  It seems that my flow takes too long to execute and am getting a "Gateway Timeout" error.  When I go to the 'executions', the status is "Cancelled".
The flow did manage to create 100 of the expected 118 Jira issues.
Thanks again for the assistance.  Any guidance on the 'Gateway Timeout' part would be greatly appreciated.  I will be trying to figure it out in the meantime.
Jon11
I'm seeing the same error in a similar situation.
@Amed M - would you mind sharing the resolution for the gateway timeout?
