Flow Designer, IntegrationHub and PowerShell Step
gaurip
Mega Expert
Hi friends,
We have a requirement to integrate some of our Service Catalogue Items with Microsoft Exchange.
e.g. Add, Modify or Delete Distribution Lists
We are planning to implement this using IntegrationHub, with the help of Powershell Step. We are still in process of activating PowerShell Step so I don't have a clear view of how this exactly works.
Specific question I have here is, we want to populate front-end form fields using data in the Exhange Server
e.g. We have"Domain" as a select box field on the form. And I want it to be populated with all the available domains in MS Exchange.
Is this also achievable via PowerShell Step plugin?
Any help would be much appreciated. Thank you.
13 REPLIES 13
Yes flow designer are good option to go with. But just check you have that MS exchange spoke in flow designer.
Ashutosh
Thanks @Ashutosh Munot.
I'll be making use of Microsoft Exchange Spoke and PowerShell Step which are available under IntegrationHub Flow Designer. I believe it would be an integration between MS Exchange Spoke and MS Exchange via MID Server.
Will explore this further and keep you posted about how I go 🙂
Thank you for your assistance.
HI,
Then no issues. It will be easy. I have used powershell in one of my flow designer video for alert management rules. You can cheeck that out.
If you need any help just shout and i can help.
Ashutosh
Abhay7
ServiceNow IntegrationHub Action Step - PowerShell plugin is Paid or free ?
