Flow designer- task sysid
Sonali Jadhav
Mega Expert
Hi ,
i am creating flow for catalog item through flow designer.
i am creating one catalog task ,in the next action i need to write one script where i need sys_id and assignment group of previously created catalog task.
how can we get that sys id and assignment group in the script.
can someone please help me with this.
While creating action, you will create inputs for it. Create input like below. Then you can use this variable in your action.
When you'll call this action, it will ask for input from flow. Pass the sys_id from data pills to this action.find_real_file.png
Calling from flow:
Jagjeet Singh
ServiceNow Community Rising Star 2022/2023
Ankur Bawiskar
As mentioned by Jagjeet you can use that data pills for the catalog task in your script section
Example below you can try
var desc = fd_data._2__create_catalog_task.catalog_task.assigned_to;
return desc
Hi ,
i am creating new action where i am using run script activity.....can we use same script there?
if you are creating custom flow action then send the 2 field data as input to it
ok...How can we pass created catalog task sys id there?
Calling from flow:
Jagjeet Singh
