Flow Designer trigger when comment added to Incident record
gavinc
Giga Contributor
In Kingston Flow Designer, I would like to create a Flow for Incident when comment added to incident, it will trigger the Flow and perform Incident field change. However, I am not able to select "Additional Comments" from condition builder. Any ideas?
Raju Koyagura
I don't think we can add it because its a journal field not available in condition builder (But still don't know why it is available in some other places of condition builder). It sounds like a plat form limitation of Flow Designer, better check with HI support if there is any work around.
Raju Koyagura
Yes, the journal field also not available in the condition builder in Workflow.
Siva74
To get any table listed under Trigger's in Flow Designer add the table to glide.ui.permitted_tables system property.
In this case, add trigger on Journal table and reference to sys_id of incident table.
Ranjani
