Flow Queuing Issue
01-24-2025 05:52 AM
Hi team,
At times, my flow gets queued and takes around 30 minutes to process. Is there any specific reason for this, and how can I prevent it from being queued?
01-24-2025 06:09 AM
Hello @monica_detani
That is the expected default behavior of a Flow.
It runs async in the background, and if there are many flows triggered at the same time, they will be queued.
You can change this behavior by running the Flow in foreground instead.
You can also check this KB -
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB1179826
Thanks & Regards
Viraj Hudlikar.
