Flow that automates adding group type to a user group with specific conditions
Wendy20
Hi all,
I am looking to create a flow that automates adding "group type" to a user group  that contain a certain word. for example all groups that contain the word "change" will be added Group type "ITIL".  Any advice on how to do this with flow designer will be appreciated. Thank you!
2 ACCEPTED SOLUTIONS
You can create a onBefore insert a business rule with condition name contain "change" set type as "ITIL".
Thanks and Regards,
Saurabh Gupta
Remove set Action value as itil and check the advance checkbox and write below code
	// Add your code here
	var curTyArr=[];
	var curTy=current.getValue('type');
	if(curTy)
		curTyArr=curTy.split(",");
	curTyArr.push("1cb8ab9bff500200158bffffffffff62");//Type as ITIL
	var au=new ArrayUtil();
	current.setValue('type',au.unique(curTyArr).join(","));//
})(current, previous);
Thanks and Regards,
Saurabh Gupta
	var curTyArr=[];
	if(curTy)
Thanks and Regards,
Saurabh Gupta
Thank you so much for your help.
