10-30-2019 11:43 PM
Greetings..!!
I was looking for a solution related to Service Catalog.
We were having a requirement, where we want whatever values we provide on the catalog item form, on clicking on Order Now, the values along with the variable name should get generated in .csv format.
For example,
If there are 2 variable (Name & Age)
and Values entered respectively is (Angshuman & 24)
post this when we click on Order Now, the same information should get generated in .csv format marking Name & Age as to Column names and its values as records entered under each column.
Any leads to this will be very helpful.
Angshuman
10-30-2019 11:51 PM
following script you can add in the workflow attached to the RITM
or have this in after insert business rule on sc_req_item table
give your own file name
this will add a csv file as an attachment to the RITM record
var ritmSysId = current.sys_id;
var set = new GlideappVariablePoolQuestionSet();
set.setRequestID(ritmSysId);
set.load();
var vs = set.getFlatQuestions();
var valuesArray = [];
var csvHeader = [];
for(var i=0;i<vs.size();i++){
var variableLabel = vs.get(i).getLabel();
csvHeader.push(variableLabel.toString());
var variableValue = vs.get(i).getDisplayValue();
valuesArray.push(variableValue.toString());
var csvHeaderRow = csvHeader.toString();
var valueRow = valuesArray.toString();
var sa = new GlideSysAttachment();
var document = csvHeaderRow + "\n" + valueRow;
var ritmRec = new GlideRecord('sc_req_item');
ritmRec.get(ritmSysId);
sa.write(ritmRec, "data1.csv", "test/csv", document);
Also posted a blog for the same:
https://community.servicenow.com/community?id=community_blog&sys_id=e4f8bd4edbbc881014d6fb243996190e
11-04-2019 08:45 PM
Hi Ankur,
Can you please review the below code and let me know if possible.
Angshuman
11-04-2019 08:53 PM
Hi Angshuman,
Actually didn't get a chance to check on that; will keep you posted
11-04-2019 08:56 PM
Thanks a lot Ankur...!!
Actually its a bit urgent, so anyways take your time, but please do let know... 🙂
Thanks again,
Angshuman
11-04-2019 09:05 PM
Hi Anghuman,
just now updated; please check
11-06-2019 01:12 AM
Hi Ankur,
Is there any update in relation to the code which I had provided.
Did you get time to check?
Angshuman
