get MVRS values in catalog client script
07-21-2022 03:13 AM
var mvrsvalues= JSON.parse(g_form.getValue('mvrs_name'));
g_form.addInfoMessage(mvrsvalues)
is it not possible to get mvrs json in catalog client script ?
I'm just trying to log the json string and it doesnt work, trying in onchange of a variable of MVRS using catalog client script for a catalog item
Request Management
07-21-2022 03:30 AM
thank you, then how would certain validations can be done, do you have any suggestions ?
if we need to validate some variable in MRVS with other same variable in added rows in MRVS
I'm just trying to compare some values in MRVS in onchange client script with already added rows in MRVS.
07-21-2022 03:31 AM
you can refer this link which tells you how to detect the add/remove row
Based on that you can try to do the validation
MRVS detect when a row is removed or deleted
07-21-2022 03:42 AM
Thanks for the link to the post, I have to compare before submit.
So I cannot use sc_multi_row_question_answer to compare.
07-21-2022 03:53 AM
you can get complete JSON from MRVS in an onSubmit catalog client script and perform the validation
07-25-2022 12:10 AM
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
