Not able to retrieve Multi Row variable set data using onSubmit client script
Deepika18
I'm unable to retrieve MRVS data from onsumbit client script. I have a requirement to get the total value of seats into a variable outside of MRVS. I'm using on submit client script.
Below is the code which I tried
function onSubmit() {
var gr = g_form.getValue(#varibale set name);
var parser = JSON.parse(gr);
var sum = 0;
alert(parser);for(var i=0;i<parser.length;i++){
sum = sum + parseFloat(parser[i].seats);  // variable name inside MRVS
alert(sum);
I'm getting gr value as empty and the total field is also not updating. Please help me in getting the total value into a variable outside of the multi row variable set.
Sai Kumar B
Hi Author,
To access the outside variables do the below
First, You would need to create an Onload script in your catalog item, with isolate script set to false:
function onLoad() {
   //We need to make the g_form object for the parent item available for later
    this.cat_g_form = g_form;
Once that is in place, you can use something like in a script on the MVRS (also set to isolate script false).
    var multiRowVariableSet = JSON.parse(g_form.getValue('demo_variable_set')); // Replace your variable set Name and not label here.
    var totalCost = 0;
    for (var i = 0; i < multiRowVariableSet.length; i++) {
        totalCost += multiRowVariableSet[i].Variable_Name; //add all totals from the MRVS to 1 total
    alert(totalCost);
	//Service Portal logic
    if (this) {
        this.cat_g_form.setValue('variable_name', 'totalCost');
		//Native UI logic
        parent.g_form.setValue('variable_name', 'totalCost');
28 REPLIES 28
Ankur Bawiskar
Did you give correct name of mrvs variable set?
yes. backend names are all correct, I rechecked it
But
from the above line :  gr is holding empty value.
did you try checking any error in browser console?
no. checked with alerts where we found that getvalue is not working
