Get user location and it region with script include call through the client script
sivananda80
Get user location and it region with script include call through the client script,
I wrote the both script include and client script, but didn't get results, Its getting null alert.  Can u please check my code and attachement
script include:
var reqtest = Class.create();
reqtest.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getDetails: function() {
//Get the sys_ID for the call
//pass the input
var callerSysID = this.getParameter('sysparm_callerSysID');
//glide the user table for fetching the records
gr.get(callerSysID);
var mgr = gr.getValue('u_emploment_counrty.u_it_region');
var loc = gr.getValue('location');
var arr = []; // define the array
arr[0] = mgr; //set the manager in the array
arr[1] = loc; //set the location in the array
return JSON.stringify(arr);
type: 'reqtest'
client script:
var callerSysID = g_form.getValue('caller_id'); //push the sysID of the caller record
var ga = new GlideAjax('reqtest'); //call the script include
ga.addParam('sysparm_name','getDetails'); // call the function of include
ga.addParam('sysparm_callerSysID', callerSysID); //pass the fetched call sys_id in the include
ga.getXML(handleResponse);
function handleResponse(response){
var answer = response.responseXML.documentElement.getAttribute("answer"); //fetch the response from script include
var answers = answer.evalJSON(); //evaluate the response and decode it
alert(answer);
g_form.setValue('u_region',answers[0]); //set the short description
g_form.setValue('location',answers[1]); //set te description
Thank you
4 ACCEPTED SOLUTIONS
you did not copy script include correctly
remove everything from script and add this again and save
		var mgr = gr.u_emploment_counrty.u_it_region.toString();
		var obj = {}; // define the array
		obj["mgr"] = mgr; //set the manager in the array
		obj["loc"] = loc; //set the location in the array
		return JSON.stringify(obj);
	type: 'reqtest'
@Siva
Hope you are doing good.
If so, please mark appropriate response as correct & helpful so that the question will appear as resolved for others who may have a similar question in the future.
If not, please let us know if you need some more assistance.
Thanks!
Hi I used this code for get location from requested by on change form and then set the location on work notes when requested by change . but return the sys_id . not the location. can you help me to this please
14 REPLIES 14
script include
	type: 'reqtest'
@Siva
Thanks!
@Siva
Thanks!
