Getting 3rd party data and showing in catalog variable
imkhan
Hi everyone,
Can someone please help me with where the issue is while parsing the variable data? we need to show data in variable
Created a script include from which to get third-party data and show it in the catalog variable.
{"result":{"catalog_item":"3a25637b47701100ba13a5554ee490a0","variable_name":"locationdata","choices":[{"label":"mumbai","value":"3"},{"label":"delhi","value":"2"},{"label":"Passing","value":"1"}]}}
script include:
var CatalogDataFetcher = Class.create();
CatalogDataFetcher.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getThirdPartyData: function() {
        try {
            var restMessage = new sn_ws.RESTMessageV2('catlog varaible data get', 'get the catalog varaible data');
            var response = restMessage.execute();
            var httpStatus = response.getStatusCode();
            var responseBody = response.getBody();
            if (httpStatus == 200 ) {
                  // Parse the response (assuming JSON)
                var data = JSON.parse(responseBody);
                return data; // Return the data to the client script
                gs.error('Failed to fetch data from API. Status: ' + httpStatus);
                return null;
        } catch (ex) {
            gs.error('Error in FetchDataFromThirdParty: ' + ex.getMessage());
            return null;
    type: 'CatalogDataFetcher'
client script:
function onLoad() {
    var ga = new GlideAjax('CatalogDataFetcher');
    ga.addParam('sysparm_name', 'getThirdPartyData');
    ga.getXMLAnswer(ajaxResponse);
    // Function to process the response
    function ajaxResponse(response) {
            alert('API Response: ' + response);
            // Parse the JSON response
            var data = JSON.parse(response);
            alert('Parsed Data: ' + JSON.stringify(data));
            // Check if data
            if (data && data.length > 0) {
                alert('Data is valid and not empty');
                var options = '';
                for (var i = 0; i < data.length; i++) {
                    // Customize this based on your API response structure
                    options += '<option value="' + data[i].value + '">' + data[i].label + '</option>';
                alert('Options: ' + options);
                // Populate the variable
                g_form.setOptions('locationdata', options);
                alert('Dropdown populated successfully');
Result:
API Response: [object Object]
You need to store that data as choices on the variable, or use a remote table if you need both the value and label continuously
13 REPLIES 13
Please use JSON.parse(data),
Also share the payload (with redacted values if needed) so we can confirm you are correctly trying to access values.
Hi Kieran,
The Error throwing on alert.
Error in cache: Cannot read properties of undefined (reading 'length')
Response:
parse data:"{\"data\":[{\"Topic\":4,\"Name\":\"A & E\",{\"Topic\":1,\"Name\":\"Eco\",{\"Topic\":3,\"Name\":\"I& B\",{\"Topic\":5,\"Name\":\"Le\"}],\"message\":\"Success\"}"
Before the for loop is working and getting data, the for loop is not able to check and proceed to parse data that is coming.
  for (var i = 0; i < JData.data.length; i++)
So your response doesn't have the fields you want. Using your example data, your code would look closer to the following:
     console.log('debugging API response');
     console.group();
     console.log('response from ajax call is ' + response);
     var responseObj = JSON.parse(response);
         console.log('Parsed response obj');
     console.log(responseObj);
     console.log("does obj have a data key? " + responseObj.hasOwnProperty('data'));
     if (!responseObj || !responseObj.hasOwnProperty('data') || !Array.isArray(responseObj.data)) {
         console.error('data not available in obj')
         console.error(responseObj)
         console.groupEnd();
         return
     var dataLength = responseObj.data.length;
     g_form.clearOptions('locationdata');
     console.log('Cleared locationdata options');
     for (var i = 0; i < dataLength; i++) {
         console.group();
         console.log('Topic is ' + responseObj.data[i].Topic);
         console.log('Name is ' + responseObj.data[i].Name);
         g_form.addOption('locationdata', responseObj.data[i].Topic, responseObj.data[i].Name, i);
         console.groupEnd();
     console.groupEnd();
Use your browsers dev tools to see the logs
Hi Kieran,
I added logs and troubleshooting and can see the "data not available in obj" on console, which is not holding data, but before and after that can see the data in json.
After line console.error('data not available in obj') the console.error(responseObj) showing correct responseObj.
One more error " *** WARNING *** GlideAjax.getXMLWait - synchronous function - processor: AjaxClientHelper".
That is because the response from your Ajax call is different to what you provided in your post.
     console.group();
     console.log("does obj have a result key? " + responseObj.hasOwnProperty('result'));
     if (!responseObj || !responseObj.hasOwnProperty('result') || !Array.isArray(responseObj.result)) {
         console.error('result not available in obj')
         console.groupEnd();
         return
     var dataLength = responseObj.result.choices.length;
         console.group();
         console.log('Topic is ' + responseObj.result.choices[i].Topic);
         console.log('Name is ' + responseObj.result.choices[i].Name);
         console.groupEnd();
     console.groupEnd();
