Getting Error: java.sql.BatchUpdateException: Duplicate entry 'e05dd3c82b45e100b641825319da15e4' for key 'PRIMARY'
m_servicenow
When i m submitting PC ordering through record producer always i m getting following
Error which is in screenshot...
Find the attached screenshot....
Thanks in advances..
12 REPLIES 12
Hi Subhajit,
I clear the cache.do but still i am getting same error... why this is happening i m not getting..
Hi Subhajit,
When you mention clearing the cache, would a cache.do fix it?
If so, you do not need to reach out to HI.
Or am I missing something?
Best Regards
Tony
Bhavesh Jain1
Giga Guru
1. Activate Debug Business Rules
2. Raise a catalog request
3. Once you see the error, scroll to the bottom of the page and see what are the business rules that are running. See if any of them is a customised BR written by you or your team.
I am also getting same issue, how to fix this issue.
Balaji Chara
ProbirDas
Dear Mukesh,
To which table the sys_id is referring to? It should be either Request or Requested Item. Go to that table and check whether in any business rules (insert/update) defined for that table, if you have used current.update().
Probir
