06-20-2019 06:30 PM
I need to trigger a reminder email on 7 days to users who have had a survey created, but not answered it.
I have:
1) created an event for this
2) created an email notification (with the unique survey link for the user) triggered by the event
3) created a scheduled job - to identify the records and fire the event.
I have created a heap of surveys in our DEV instance, and updated sys_created_on to have records on a range of days so I can validate the script.
I have been using a background script to identify the records that will trigger notification - and they seem to be out by 10 hours (we are in UTC).
Script:
var gr = new GlideRecord('asmt_assessment_instance');gr.query();
while (gr.next()) {
if ((gr.state == 'ready') && (gr.sys_created_on <= gs.daysAgo(6)) && (gr.sys_created_on >= gs.daysAgo(7))) {
gs.print (gr.number + " " + gr.sys_created_on);
Records found:
*** Script: SURVEY0010835 2019-06-14 04:23:43
*** Script: SURVEY0010821 2019-06-14 20:23:43
*** Script: SURVEY0010822 2019-06-14 10:23:43
*** Script: SURVEY0010826 2019-06-14 22:23:43
*** Script: SURVEY0010817 2019-06-14 22:25:16
My issue is that this is not the actual dates that they were created >> see below
Background Script - SN when viewing survey
SURVEY0010835 2019-06-14 04:23:43 - 14-06-2019 14:23:43
SURVEY0010821 2019-06-14 20:23:43 - 15-06-2019 06:23:43
SURVEY0010822 2019-06-14 10:23:43 - 14-06-2019 20:23:43
SURVEY0010826 2019-06-14 22:23:43 - 15-06-2019 08:23:43
SURVEY0010817 2019-06-14 22:25:16 - 15-06-2019 08:25:16
Is there anything I'm missing to easily identify items from 7 days ago? I have seen scripts a lot more complicating using date & time functions ..... I was hoping to do it in a simple way if possible as I'm not super strong at scripting.
06-20-2019 06:49 PM
Example using Incident - email Assigned to user until resolution every 7 days
06-20-2019 06:51 PM
06-20-2019 06:59 PM
The only issue I see with this is that the email notification we need to send has a fair bit of coding around it, and is in the notifications area.
I think when you choose: "send email" - you can generate an email - in rich text format - not html?
I guess I could look at a custom action to trigger the event though.
You definitely have me on the right track now thanks!
