Grab emails sent using Email Client and add into activities (filtered)
carlos_monchuch
Giga Contributor
Hi all, seen a few threads on this and none seem to answer the question exactly.
What i need is a way to grab the email sent using the email client, and insert into activities, just like customer communication does.
Yes i can insert this into the comments field, but that will duplicate the email, i can add to work notes, but that adds confusion.   I just would like to insert into activities somehow?
In previous posts answered, advice is to add "send/received emails" to the activities filter, this works fine for comments updated but not when email client is being used to send.
On that, if i could make the comments section an HTML field, and add an attachment function to the field all my issues would be solved, i could remove the email client icon all together form the top right as the only reason this is used mainly is to add attachments.
Any assistance appreciated.
jagannaths
Kilo Expert
Hi Carl,
The sent/received emails should also show the emails sent using the "email client". Just confirming, you are using the OOB email icon that appears on the top of the screen, correct?
Swathi
9 REPLIES 9
Hi Michael,
Just curious:
Did you right click where it says "Activity" (under Activities tab or section) and then Personalize Activities?
If you haven't, try it and look for "Sent/Received Emails" on the left side of the list.
Harel
In Eureka the activity list can be filter by clicking on the arrow to the right of the Activity label.   It shows a number of checkboxes but email is not one of them..
Hi Michael,
Yes, you will not see it there, even if it is in the list of activities.
Try right clicking next to the activities:
and then find Send/Receive
Harel
Excellent! I was right-clicking directly over the "Activity" keyword and getting the normal browser context menu.   When I right-clicked directly over the list of activity types I could see the "Personalize Activities" option.   I have it working now.
Thanks so much.
    Michael
Pleasure
