Help on Celledit client script
Naga Ravindra R
I have two date fields, start date and end date.
I have written oncell edit client script like below:
function onCellEdit(sysIDs, table, oldValues, newValue, callback) {
    var saveAndClose = true;
    var strDate = g_form.getValue('start_date');
    var endDate = g_form.getValue('end_date');
    if (endDate < strDate) {
        alert("st= " + strDate + '  ' + "end= " + endDate);
    callback(saveAndClose);
But it is not working. It working fine on onchnge client script.
Any suggestions?
Rutuja Khalate
Hi @Naga Ravindra R
You can add an alert in the client script like the below:
var saveAndClose=true;
var daAjax = new GlideAjax('DateValidate');
daAjax.addParam('sysparm_name', 'datevalidation');
daAjax.addParam('sysparm_sys_ids', sysIDs);
daAjax.addParam('sysparm_end_date', newValue);
daAjax.getXMLAnswer(dateResult);
function dateResult(answer){
if(answer=='false')
alert('End date should not be before start date');
callback(answer === "true");
And remove last 'return true; ' from script include:
var DateValidate = Class.create();
DateValidate.prototype = Object.extendsObject(AbstractAjaxProcessor, {
datevalidation: function(){
var sys_id = this.getParameter('sysparm_sys_ids');
var endDate = new GlideDateTime(this.getParameter('sysparm_end_date'));
var events = sys_id.split(',');
for (var i = 0; i < events.length; i++) {
gr.addQuery('sys_id', events[i]);
if (gr.next()) {
var strDate = new GlideDateTime(gr.u_start_date_2);
var comp_date = endDate.compareTo(strDate);
if (comp_date == -1) {
return false;
return true;
//return true;
type: 'DateValidate'
Best Regards,
Rutuja Khalate
9 REPLIES 9
Rutuja Khalate
Hi @Naga Ravindra R
when you are in a list, g_form (which works on the FORM) isn't available, that's why it doesn't work.
onCellEdit doesn't have access to the form, it gives you some control over fields on a list but you can't do conditional stuff like this.
There are 2 ways as below:
1. You can use a GlideAjax call in your onCellEdit() client script. You can retrieve the current value of your field.
2. To fulfill your requirement you can use a before insert/update business rule, set the condition and then in the actions tab tick the abort action box and add a message to your users.
Best Regards,
Rutuja Khalate
Rutuja Khalate
Can you try below:
Client script on End Date field:
And script include as below:
var gr = new GlideRecord('x_diocg_service_al_event');
if (gr.next()) {
var strDate = new GlideDateTime(gr.start_date);
return false;
return true;
return true;
Best Regards,
Rutuja Khalate
Hi @Rutuja Khalate
This is working fine, but I have to show error message or alert message. If user enters end date before start date.
If I add alert, it is popping up in both scenarios. (+ve and -ve)
Rutuja Khalate
Hi @Naga Ravindra R
if(answer=='false')
if (gr.next()) {
return false;
return true;
//return true;
Best Regards,
Rutuja Khalate
Rutuja Khalate
Hi @Naga Ravindra R ,
Best Regards,
Rutuja Khalate
