Hide Empty Variables in RITM and Task
‎04-04-2020 05:45 AM
I am working in service catalog. after submitting the service catalog i want to display only the variables which is available on the form view. I wrote some UI policy to hide some fields based on conditions.
But in RITM and Task all variables is showing including empty variablles. could you please help me on this.
Service Catalog
‎04-05-2020 12:26 AM
Hi Santhosh,
Did you try to print the variables in array?
gs.info('Variables is: ' + emptyVars);
‎04-04-2021 09:51 PM
Hope you are doing good.
If so, please mark appropriate response as correct & helpful so that the question will appear as resolved for others who may have a similar question in the future.
Thanks!
‎09-23-2021 05:39 AM
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
‎04-04-2020 10:34 AM
Hi
OnLoad Client script to hide Variables (a copy of this exists within the task, sc_req_item, and sc_task tables):
function onLoad() {
//Hide all empty variables using the scratchpad object passed from 'Hide Empty Variables' business rule
if(g_scratchpad.emptyVars != ''){
var emptyVars = g_scratchpad.emptyVars.split(',');
for(i = 0; i < emptyVars.length; i++){
g_form.setDisplay('variables.' + emptyVars[i], false);
If it help mark helpful or correct
Thanks and regards
Anil
‎04-04-2020 11:20 AM
