Hide Options from Select Box
jessicaa_perry
For the Create Incident form, I added Category as an option.  I was able to add this option and it inserts into the Incident table.  Success!
However, I only want a few categories available for our users to choose from in this form.  We'll call these internal vs. external categories.  How do I hide the internal categories?
After some research, I'm trying to use the onLoad function with the g_form.removeOption, but I can't seem to get it to work.  This is my first time working with client scripts.
15 REPLIES 15
Francisco Lopez
Kilo Explorer
Hello to everyone, for this expose case I suggest to implement the following client script, you need to consider that the variable where you going to show the option needs to be empty 🙂 (thats the trick )
if (isLoading||newValue=="") {
switch (newValue) {
case"marca_ibm":
//Remove options first for a possible option change
g_form.removeOption(
"tipo_falla",
"Envia Mensaje Access Error LAN",
"tipo_falla",
"Envia Mensaje Communication with model layer has Failed",
"tipo_falla",
"Envia Mensaje Error de Acceso",
" Envia Mensaje Error de Acceso"
//Show the correct options base on the "marca_ibm" variable.
g_form.addOption(
"tipo_falla",
"Envia Mensaje Another instance of the Toshiba JavaPos drivers is already",
g_form.addOption(
"tipo_falla",
"Aplicacion no termina de cargar",
g_form.addOption(
"tipo_falla",
"Envia Mensaje Device Offline for logical name POS Printer 1",
break;
