Hide Variable based on Select Box choices
NowTechie
I have a select box variable with multiple choices, I need to show other variables based on select box choices.
  • If choice A is selected, variable AB and AC should be visible.
  • If choice B is selected, only variable AB should be visible.
Am able to achieve the condition through onChange client script but when I select A first and then B, it is not hiding AC.
if(choice == "A"){
g_form.setVisible('AB', true);
g_form.setVisible('BC', true);
if(choice == "B"){
14 REPLIES 14
@Ankur Bawiskar Logic is not working, when selecting choice B after A, It's not hiding the variable AC.
@NowTechie
is that variable mandatory? if yes then it won't hide unless you make it non-mandatory
No, that variable is not mandatory
@NowTechie
then script should work fine.
please share your complete script here and what debugging did you perform
@NowTechie
Hope you are doing good.
