Hide Variable based on Select Box choices
NowTechie
I have a select box variable with multiple choices, I need to show other variables based on select box choices.
  • If choice A is selected, variable AB and AC should be visible.
  • If choice B is selected, only variable AB should be visible.
Am able to achieve the condition through onChange client script but when I select A first and then B, it is not hiding AC.
if(choice == "A"){
g_form.setVisible('AB', true);
g_form.setVisible('BC', true);
if(choice == "B"){
14 REPLIES 14
Dr Atul - LNG
Medi C
@NowTechie
You won't need to script, please use UI Policies instead
First one:
Condition: Choice != A (Choice is not A)
Reverse if false = True
UI Policy Action:
- Field: AB.  Visible = Fasle, FieldAction = ClearValue
- Field: AC.  Visible = Fasle, FieldAction = ClearValue
Second one:
Condition: Choice != B (Choice is not B)
UI Policy Action:
Dr Atul - LNG
Hi @NowTechie
Do it via UI policy that is low code and easy.
Medi C
If there is no escape from Client Script, you should take care of the negation as well:
    // Show variables based on the selected choice
    if (newValue == 'A') {
        g_form.setVisible('AC', true);
     if (newValue == 'B') {
        g_form.setVisible('AC', false);
@NowTechie
I hope you are doing well!
Did it work ? Was my reply helpful?
