How do I create a client script just for Agent Workspace?
Amy13
Looking to clear a field on the Incident form with an onChange client script. I want this done for Agent Workspace -- how do I do create one such that it executes in Workspace?
Note: I've got a UI Policy set up that works for the platform and Agent Workspace. However the "clear value" field ONLY works in the platform and not in workspace (not sure why).
Ankur Bawiskar
you can specify the view for your client script as -> workspace
then write your code which would run only for the workspace view
9 REPLIES 9
uncheck Global checkbox and then you can see that view field
Hello Ankur,
I am trying to apply this for a onchange client script where I have to clear the assigned_to field when the assignment group changes.
I have tried using below options but none is successful - Kindly have a look.
    var description = '';
  // if(description != "simbatestalert"){g_form.clearValue('assigned_to');}
   //g_form.setValue('assigned_to','');
   setTimeout(function () { g_form.clearValue('assigned_to'); }, 100);
uncheck the global option then you will be able to see view option
Uncheck the global checkbox
can you pls tell what client script need to be written in workspace for getting search option in the workspace
