How do I print details from a RITM or SCTASK?
trishlipe
Giga Expert
We need a way to print the ticket Details to get sign off from end users.
When I export to a PDF document the details are not listed (See screenshot below). When I try to right click --> print, the format is not usable. How do I get this information to print on the PDF download?
Jag5
Hi Trishlipe,
You can print the variables from RITM by creating a UI page, Script Include, and UI action.
Script Include: fetchVariables1, client callable = true
var fetchVariables1 = Class.create();
fetchVariables1.prototype = Object.extendsObject(AbstractAjaxProcessor, {
itemVariables: function() {
var itemID = this.getParameter('sysparm_item');
var displayValue = '';
var desc = '';
desc += '<table style="width:100%" cellpadding="0" border="1">';
desc += '<tr>';
desc += '</tr>';
var newLineHTML = '';
var variables ='variables.';
var grItem = new GlideRecord('sc_req_item');
grItem.get(itemID);
var gr = new GlideRecord('sc_item_option_mtom');
gr.addQuery('request_item',itemID);
gr.orderBy('sc_item_option.order');
var i = 0;
while(gr.next()) {
/* Put all variable values and labels from the variable pool into an array */
/* Only include non-empty variables, and exclude Label and Container variables */
//gr.sc_item_option.value.getDisplayValue() != '' gr.sc_item_option.value.getDisplayValue() != 'false'
if ( gr.sc_item_option.value.getDisplayValue() != 'false' && gr.sc_item_option.item_option_new.active == true && gr.sc_item_option.item_option_new.type != 11 && gr.sc_item_option.item_option_new.type != 19 && gr.sc_item_option.item_option_new.type != 20 && gr.sc_item_option.item_option_new.type != 14 ) {
//desc += j+") "+ v.getGlideObject().getQuestion().getLabel() + ': ' + v.getDisplayValue() + '<br>' ;
if(gr.sc_item_option.item_option_new.question_text == 'Current Annual Base' && i%2==1){
i++;
if(gr.sc_item_option.item_option_new.question_text == 'Current Supervisor' ){
//i++;
if(i%2==0) {
desc += '<tr>';
variables += gr.sc_item_option.item_option_new.name;
displayValue = grItem.getDisplayValue(variables);
if(displayValue==null || displayValue == undefined) {
displayValue = '';
if(gr.sc_item_option.item_option_new.question_text == 'Comments') {
newLineHTML += '<table style="width:100%" cellpadding="0" border="1">';
newLineHTML += '<tr><td style="text-align:left;padding:4px;width:20%;background: #80808040;"><span style="text-align:left;font-weight:900;padding:2px" >' + gr.sc_item_option.item_option_new.question_text + '</td><td style="width:80%;padding:4px;"></span><span style="text-align:left;white-space: pre-wrap;"> ' + gr.sc_item_option.value + ' </span></td></tr></table>';
else {
desc += '<td style="text-align:left;padding:4px;width:20%;background: #80808040;"><span style="text-align:left;font-weight:900;padding:2px" >' + gr.sc_item_option.item_option_new.question_text + '</td><td style="width:30%"></span><span style="text-align:left;white-space: pre-wrap;"> ' + displayValue + ' </span></td>';
if(i%2 == 1) {
desc += '</tr>';
i++;
desc += '</table>';
desc += newLineHTML;
type: 'fetchVariables1'
UI PAge: item_variables
HTML:
<link href="kb_styles.cssx" type="text/css" rel="stylesheet" />
<div id ="html_content" style="display: none;">
$[sysparm_item]
</div>
<div id='printClass'>
<div id="commentsdiv" style="display: block;">
<h4 style="font-weight: bold;">Status Change Form for: $[sysparm_number]</h4>
<!--<table>
<span><label for="comments">$[sysparm_item]</label></span>
</table> -->
<div id="variable_data"></div>
</div>
</div>
<input type='button' id='btn' value='Print' onclick='printPage();'></input>
</j:jelly>
Client Script:
var ga = new GlideAjax('fetchVariables1') ;
ga.addParam('sysparm_name','itemVariables');
ga.addParam('sysparm_item',document.getElementById('html_content').innerHTML);
ga.getXMLWait();
var val = ga.getAnswer();
//alert(val);
document.getElementById('variable_data').innerHTML = val;
function printPage()
var divToPrint=document.getElementById('printClass');
var newWin=window.open('','Print-Window');
newWin.document.open();
newWin.document.write('<html><body onload="window.print()">'+divToPrint.innerHTML+'</body></html>');
newWin.document.close();
setTimeout(function(){newWin.close();},10);
UI Action: Print Form, Table: Requested Item Onclick: printVariables()
function printVariables(){ //Client Side function
var sysid = g_form.getUniqueValue();
var gdw = new GlideModal('item_variables');
gdw.setTitle('Variables');
gdw.setWidth(1200);
gdw.setPreference('sysparm_number', g_form.getValue('number'));
gdw.setPreference('sysparm_item', g_form.getUniqueValue());
gdw.render();
Jag.
Please mark CORRECT/HELPFUL as needed.
32 REPLIES 32
SoloSNOWadmin
Mega Contributor
I realize that this post is a little old, but this is the most helpful post I have come across for my requirement. Is it possible to add the Requested Item/Task information in the print out as well - such as when it was opened, who it was opened by, who it was requested for, etc.
Hey
Were you able to add fields from requested item table to print together with variables?
soraya_vally
Mega Guru
I cant seem to get this work either, i used the update set Jag provided, but i don't see the client script part in it?
So i used your code to create the client script but i need the following?
Not sure what im doing wrong, when i click on print it takes me to the print format but does'nt pull any variables.
Sorry it works, i think i didnt get results because of the multi row option on the London release. Any fix for this?
Kavitha Mulka
This solution is awesome.  Any idea how we could modify it so that it can process London's new Multi-Row Variable Set?
